Wet motor?
Old 05-27-2010 | 05:00 AM
03whitedually's Avatar
Wet motor?
Hey everyone , I washed down my motor yesterday and this morning it's running really rough and building real high exhaust temps. Last night I drove down the street and it was fine though . Any ideas are appreciated
Old 05-27-2010 | 07:40 AM
Spooler's Avatar
You have water in a connector. Check the rail pressure sensor, if water gets into this connector it can toast the sensor and they are not cheap.
Old 05-27-2010 | 09:37 AM
cbrahs's Avatar
had the same thing happen to mine. ran ok the day i washed it, next day, ran like a 12 valve. replaced sensor, added dialectric grease and no issues any longer.
Old 05-27-2010 | 05:38 PM
thanks guys I'll check it tonight hopefully a little dielectric grease will fix it up
Old 05-28-2010 | 05:32 PM
Well checked all the plugs that go into the fuel area added dielectric grease but still no luck. Is there anything else that I can check before taking it to a mechanic
Old 05-28-2010 | 05:36 PM
cbrahs's Avatar
pull codes. i tried cleaning mine but the rail psi sensor was already shot, had to replace it.
Old 05-29-2010 | 06:13 PM
if you mind me asking how much was the part and how hard was it to replace ( DIY project or professional )
Old 05-30-2010 | 02:24 PM
White Ghost's Avatar
you can buy the whole rail from cummins cheaper than the sensor from the dealer.
Old 05-30-2010 | 02:27 PM
cbrahs's Avatar
so true!
Mine was/is still under warranty. 1st time the truck has ever been on a wrecker. kinda hurt my ego a bit! LOL
Old 05-31-2010 | 10:29 PM
Well I decided to unplug my Edge box and guess what no more codes and runs great again just alot slower
ryan10
08-10-2007 09:38 PM
Common
05-09-2007 12:11 AM
coupdetat
02-17-2007 12:52 AM
DuaneWKKC
09-25-2005 04:02 PM
Quick Reply: Wet motor?
