well dodge bought me a motor
#46
how does one go about "adjusting" an out of round tapered cylinder without boring the hole oversize? as we all know , a hone is a fine finishing tool used to polish out super fine scratches and smooth the cylinder wall to a finish suitable for ring break in. a hone is also used after the cylinder is bored to within .001 of the final desired bore size for ideal fitment and proper piston to cylinder wall clearance. how does one go about adjusting an out of round tapered cylinder on a possibly warped, over heated "seasoned " block ?
They should bore them all to the next size available as standard practice but you never know. There are any number of things that could go wrong after that but none that have to do with a seasoned vs a new block. Maybe somebody put the standard rings in an overbore block by mistake.
#47
:quote: are you sure it is not a turbo problem that could be causing the oil consumption? :quote:
no_6_oh_no , they installed a new turbo when they dropped the motor in but this does make me curious. guess I'm still hoping it might be something simple. is a turbo using engine oil a common thing? I never really see any smoke except an occasional small blue "poof" about 30 seconds after start up.
Jim Lane
04-05-2020 06:03 AM
Cummins Freak
01-03-2010 10:00 PM
Timmay2
11-06-2005 09:57 PM
