Warranty and oil leaks?
Old 03-28-2009 | 11:31 PM
b1eric's Avatar
I changed oil today and noticed that my oil pan gasket is leaking. Not to bad but since when do leaks quit. Does the factory powertrain or the Cummins warranty cover leaks or am I SOL?
Old 03-29-2009 | 08:00 AM
rich's Avatar
i would think it would all you can do is ask worst case is they say no
Old 03-29-2009 | 08:38 AM
mini14's Avatar
it depends on how bad the leak is, they refused to change out my front crank seal they said it was "sweating", and refused to changed it.
Old 03-29-2009 | 08:39 AM
RickCJ's Avatar
How big is the puddle underneath? No puddle no leak, just sweating.
Old 03-29-2009 | 09:33 AM
CD in NM's Avatar
I had the 'weepage' at the rear of my pan, they just re-torqued the bolts. It still looks wet there to me, but no oil running down the pan. Dodge told me it had to make a puddle on the ground the size of about a quarter before they would do anything more than tighten the bolts. So far, their fix seems to have worked.
They told me the same thing about the rear diff/yoke seal, it eventually did leak big-time, they changed it. Now I see my front diff/yoke is 'weeping', I suppose it will also need replacement. I did clean the front diff vent tube yesterday, that could make a difference according to some opinions found here.
CD
Old 03-29-2009 | 09:42 AM
madhat's Avatar
Administrator/Jarhead
What I was told about leaks....
They clean the area that is leaking, then throw some dye in there... if the 'special light' does not detect the leak after xxxx amount of time, then no love.
If it's just a seep... don't worry. That's Cummins external lubrication system...
Old 03-29-2009 | 09:39 PM
Roperteacher's Avatar
Ditto to what CD in NM said. I have had the rear pan Gasket Weepage for about 30,000 miles now. Never gets any worse. I re did the rear pan bolts and all seems to be OK, Never drips or runs. I notice it does it right after an oil change. Once the oil goes black it slows way down
Old 03-29-2009 | 11:57 PM
bradler's Avatar
thought my pan was leaking as well and after cleaning it off and keeping an eye on if for a while discovered it was originating from between bell housing and pan, probably rear main seal. dealer said if it wasn't leaving a trail in the shop it wasn't bad enough to warranty. Been sweating now for a while without getting worse and never enough to drip on the ground or really worry about.
Old 03-30-2009 | 02:06 AM
Hounddog's Avatar
Check the back of the ROCKER BOX. Lots of them seep heavy from there and it runs down the back of the motor.Leaks are COVERED.On some of those oil pan bolts,take them out one at a time and use some sealer on them and reinstall.
Diesel Junkie
09-30-2012 04:18 PM
abchoppers
01-26-2011 05:38 AM
tool
08-07-2008 06:16 AM
TxDiesel007
15
01-18-2006 01:19 PM
danshsss
04-13-2004 07:24 PM
Quick Reply: Warranty and oil leaks?
