Wanna see death wobble?
Old 03-26-2007 | 08:49 PM
wreedCTD's Avatar
Does this happen on all the HD Dodge trucks?
Old 03-26-2007 | 08:52 PM
Luvnacumns's Avatar
Didn't have one problem on my 05 but the 06 has had it twice!!!
Shane
Old 03-26-2007 | 08:54 PM
Luvnacumns's Avatar
Originally Posted by ptgarcia
What's an EB?
Ch , doesn't anyone spell words out?
I agree quit abreviating crud.... I spend more time trying to figure out what people mean!!!
That DW vig is exactlyhow my truck feels!! Hope it gets fixed tomorrow!!!
Shane
Old 03-26-2007 | 08:55 PM
wreedCTD's Avatar
What is the fix?
Old 03-26-2007 | 09:11 PM
bigredBCS's Avatar
my 99 did it with x-terrains and bfg's!!!!
Old 03-26-2007 | 09:20 PM
chromegrill's Avatar
Originally Posted by bigdav160
Keep laughing.
My .03 had severe death wobbles with BFG's. Just any good size bump would set it off.
New tires and not one episode since (almost two years now). Same roads.
Tires seem to have fixed mine.
If you would have had caster set more positive it would have never happened again. The reason it happens on the newer trucks with few miles is because when a truck runs down the line and is aligned, its not very precise. This is why some trucks can have an issue with DW, and others don't. Big tires and lower air pressures can accelerate the problem, but don't cause it.
wreedCTD's Avatar
this is a stupid question but can someone post a pics of the front suspension showing me what the traction bar is, i think i know but just want to be sure.
Old 03-26-2007 | 09:21 PM
wreedCTD's Avatar
i read somewhere that the front end/steering was upgraded to hopefully prevent this problem on 06 trucks. is this true?
Old 03-26-2007 | 09:24 PM
The track bar, not traction, is the bar that goes from the frame to the axle and holds the axle in place, keeping it from having lateral movement. The drag link and tie rod both connect to the steering knuckles, one on each side.
Old 03-26-2007 | 09:27 PM
wreedCTD's Avatar
Originally Posted by JWillms81
That slow motion one shows it the best, you guys are right about it being scarier then heck, mine used to do it about 2 years ago, glad I didnt see that video back then dont think I would have taken the truck on the highway after seeing that.
JW
what did you do to fix it?
Old 03-26-2007 | 09:28 PM
dodge2005's Avatar
Those videos are very scary. Knock on wood I do not have any death wobble.
wreedCTD's Avatar
got it thanks!
Old 03-26-2007 | 09:29 PM
wreedCTD's Avatar
is the trac bar in front of the axle???
Old 03-26-2007 | 09:33 PM
ptgarcia's Avatar
No, it's above and parallel with the axle. I believe they call the piece you're thinking of the drag link.
Here are a couple pics of Thuren's adjustable track bar...
Frame Mount:
Axle Mount:
Old 03-26-2007 | 10:07 PM
rockcrawler304's Avatar
WOW, that is scary. Glade mine is OK (knock on wood )
Quick Reply: Wanna see death wobble?
