vacuum source for a '04, 600
Old 11-01-2004 | 03:56 PM
ombg's Avatar
Does a 2004 Cummins 600 have a sufficiant source of vacuum to run a vacuum/hydraulic brake setup. If so, where is the pump located.
Thanks,
AC
Old 11-01-2004 | 05:47 PM
Roger Ramjet's Avatar
The 600 does not have a vacuum system. If you have to have vacuum you should be able to purchase the vacuum pump and belt that comes with the Jake Brake through parts.
Hope this helps!
Old 11-01-2004 | 06:26 PM
xyzer's Avatar
The only vacuum source I know of on my "03" is the cruse control vacuum pump located on the drivers side near the firewall. I'm sure it isn't the size you need to run vacuum over hydraulic. But yes there is a vacuum source.
Old 11-02-2004 | 06:49 AM
ombg's Avatar
Thanks for your reply. Does anyone know if the electric vacuum pumps will provide enough vacuum??
Old 11-02-2004 | 09:13 AM
bigblock2stroke's Avatar
No, it won't have enough. Plus it doesn't exist on your truck. Your cruise is done through the computer.
Listen to RogerRamjet.
Old 11-02-2004 | 12:45 PM
xyzer's Avatar
Did you look Roger or Bigblock?..........They must have changed after "03" there is a small vacuum pump located behind the passanger side battery near the firewall.... the vacuum line runs over to and under the drivers side battery to the cruse control diaphram. I'd like to know. My 2nd generation had one and my "03" 3rd gen has one. If they changed the system in "04" I'd like to know. the computer tells the cruise control what to do but it needs a power source to accuate the throttle. Either way it isn't big enough to run brakes. I'd bet they use the same cruise control unit on there gassers. The don't need the pump...the vaccum is free.
Old 11-02-2004 | 05:09 PM
Beginning with the 04.5 or as they are known the 600 there is not any vacuum source! This is the reason the Jake Brake cost went to $1325.00 list. You have to install an engine driven vacuum pump, which comes withe the kit, to activate the Jake Brake.
Old 11-02-2004 | 07:43 PM
Artie04's Avatar
Vacuum Pump
My 04 has the electric vacuum pump on the passenger side fender back by the firewall. It is there for the servo control that does the speed control on the automatic transmission setups. I had developed a problem after 6000 miles where the speed controll was having trouble keeping up going up hills or if you used the accel button several times to speed up. Tech found the electric vacuum pump was not generating enough vacuum. Unit was replaced and all is working ok again.
Old 11-03-2004 | 01:30 AM
xyzer's Avatar
Thanks Artie! Well at least I now know the "04" and probably the "05" still have a vacuum system of sorts. I know it won't run any accessories but it does have a system and not operated buy a "computer". I noticed a buzz from that area when I engaged the crusie control and the dealer told me what I was probably hearing.
Old 11-03-2004 | 03:11 PM
1.) No vac pump on 05's at all.
2.) Jake brakes always came with vac pump. The tiny electric pump for cruise doesn't have enough vac to support the jake brake.
3.) XYZer, did you look at any trucks besides your own? You should make sure you know what you're talking about before you chastize someone.
4.) Diesels don't have throttles. It is merely a throttle position sensor. There is no butterfly valve. Those engines with the TPS on the engine (covered by black plastic and has engine data tag) will have an electric vac pump for cruise. Those engines with TPS mounted either under the battery tray (2003.5 to 2004.5 manual trans only) or in the cab attached to the go pedal (2005 autos and manuals) will not have an electric vac pump.
Old 11-03-2004 | 04:25 PM
xyzer's Avatar
Thanks again Artie!
Old 11-03-2004 | 06:20 PM
hauliday's Avatar
you will most likely have to buy the for the vacuum pump for the vacuum over hyd. to have enough vacuum to run your brakes but buy the time you buy all of that you can convert to a electric over hyd. unit that goes on your trailer and you just use a standard electric brake control thats what i did on my 40' goose neck and its great plenty of stoping power
Old 11-03-2004 | 06:59 PM
hauliday's Avatar
btw here is what the unit i have looks like and some info http://www.etrailerpart.com/brakerite.htm
Old 11-04-2004 | 07:17 AM
JamesP's Avatar
Pretty funny xyzer! but don't forget that the 600 started mid year, Artie may have an early 04 (555) with the vacuum actuated cruise.
Old 11-04-2004 | 04:45 PM
Mike_Boutet's Avatar
I believe the auto's cruise control was vacuum operated and the 6spds were controled by the computer.
Quick Reply: vacuum source for a '04, 600
