Using Acetone as a supplement
Old 12-13-2007 | 07:54 AM
DiEseLjunKy's Avatar
Hey man if you want to dump that corrosive stuff in your fuel be my guest. Just a lot of red flags raised here by several posters I can't believe anyone would.
Old 12-13-2007 | 08:45 AM
sCreamin400's Avatar
You will not find acetone in my truck. I use it to clean my drag sleds clutches with as there is no residue. I kind of like residue on my cylinder walls. I did get some on some plastic one time and was amazed at what it did to it.
Old 12-13-2007 | 10:45 AM
Thundercloud's Avatar
Wow, should I put acetone in my tank or not? Quite the conundrum. Having said that my Cummins friends, as faith would have I too have a question. Which brand of fuel additive do you use? The reason I ask is most of the additives have solvents in them, ie. Power Service.
Old 12-13-2007 | 05:36 PM
Jfaulkner's Avatar
Muted User
I did the same thing. I spilled it on a TV remote, I immediately grabbed it to clean it off and my thumb went right through it. It melted like putty. Sure makes me want to run it in my truck.
Old 12-13-2007 | 06:26 PM
duallydave's Avatar
like said before sure at full strength its very corosive but so diluted i wouldnt worry to much,ive used it in my lawnmowers and quads and even the wifes car on a long trip,i was amazed on the trip,ive tried it in my diesel a few times but didnt notice anything,i may try it again with the quad mmm tune in the x2 ive been playing with
Old 12-13-2007 | 06:40 PM
Jfaulkner's Avatar
Muted User
when your done with the acetone test try some liquid fertilizer. Some good liquid 28 should do the trick, it's corrosive and also not intended to be used as a fuel. Better yet use Amonium Nitrate. Amonium Nitrate+Diesel fuel = Oklahoma city bomb. That should increase your mileage
Just think when all these diesel engine MFG's are trying to beat one another by having the best fuel economy by spending billions on new technology all they have to do is suggest acetone as an additive. Someone is wrong, I know where I'm putting my money and it's not in an engine rebuild due to a "snake oil" fuel additive rumor. Again fuel goes in the fuel tank!
Old 12-13-2007 | 09:02 PM
Ramguy 05CTD's Avatar
a little amonia nitrate is diluted proportions would be great for your economy. I think if it were down to .001 percent it would make much more power. Just think of the cylinder pressure after adding amonia nitrate. It may be head splitting
Old 12-14-2007 | 12:30 AM
Rednecktastic's Avatar
Only solvent I know that will work in fuel is xylene. It will boost the octane of gas. Lots of people do this.... with caution to how they mix it of course .
I actually had a turbo motor built on paper for my mustang and this was how I was going to run it on the street since 93 octane wouldn't work for me if I took it on a trip and needed gas.... I built a nitrous motor that runs on pump gas instead .
Don't take my word though read up on it.
Old 12-14-2007 | 06:55 AM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
$45,000.00 Truck....
"Now lets see...What can I pour into the tank..."
I find this quite entertaining.
Old 12-14-2007 | 05:15 PM
Jfaulkner's Avatar
Muted User
Funny because I know a race car driver that uses xylene on his tires to soften them up. Should do wonders for any rubber o-rings in the fuel system.
Old 12-14-2007 | 05:20 PM
Jfaulkner's Avatar
Muted User
That's exactly what I'm getting at.
What truck did you buy that was $45k? My '05 2500 4wd loaded 6spd long bed 4dr was only $34k out the door. Either way the whole in tank chemistry set idea makes me think someone is working with acetone in a non-ventilated room!
I guess if the Gov't gets their way and mandates some high CAFE standards for automobiles all they have to do is use acetone!
Old 12-14-2007 | 07:29 PM
Good for him . You should know that xylene is already in gas from the refinary.
You can jack your octane up a bit with it. Tons of people do it.
Look at some of the high end turbo buicks and mustangs for proof.
Kelton Trent
03-17-2006 06:21 PM
Katmandu
02-08-2006 01:58 PM
CRSmith
12-05-2005 08:55 AM
DodgeCowboy
14
10-31-2005 10:46 PM
rlyoung
11-03-2003 08:37 PM
Quick Reply: Using Acetone as a supplement
