Update On My Cooper Tire Problem
Well i found out tonight that i probably have two bad brand-new cooper ATR tires. Well my truck started getting a bad vibration in it tonight. So i went to wal-mart wear i used to work at and had my friend check out the balance on the tires. I had the coopers (cant spell) balanced with all the weight on the inside of the wheel. Well the left front took 3.50 ounces to balance. the right front took 4.00 ounces to balance. here is wear it gets bad the left rear tire took 10.0 ounces to balance and the right rear took 9.00 ounces to balance. so do you guys think that might be whats making my truck wandered all over the road?? I mean the truck drives fine in a straight line. It just feels like you are driving with to flat tires on the back. If you turn the wheel back and forth real fast. So looks like i am not going to be driveing my truck any more until i get my tires fixed. I might see if i can change to a toyo open country at tire.who all makes a load range E tire in a 285/70/17 LT.Forgot to say that i did get rid of the vibration i had. Thanks Bobby
Ive heard the Cooper ATRs are wiggly til they get a few miles on them. I have the 286/75r16 ATRs on my Ram,and they are not wiggly at all.They are a very nice tire.They are on 2 yrs this month,and are wearing much better than the At's I had before.
yes you are right that is a lot of weight. These tires have less thjan 50 miles on them and have a warrenty. so i am going to call the place wear i got them and see what they can do for me. So what tire manufactor would you recomend that sells a 285/70/17 LT load range E tire for my truck? thanks Bobby
trust me i would not have left the shop eather.But the wheels were not on the truck when i had the tires mounted.so i did not know about it untill i put them on my truck. I am going to call the tire shop monday and see what they are going to do. I will let every one know what happens.thanks for all the help guys. Mopar72
Hi the rims are in good shape. I traded my eagle 186 wheels for these wheels. they were off of a 07 CTD. allso i watched my friend blance all my wheels so i could look for a bent rim. But thanks for the help. mopar72
What kind of tire pressure are you running? I have a dually and when I left the shop the last time I had tires put on, I thought I was gonna lose control all the way home,but when I got home and checked, I found that they had put 85 psi in all my rear tires.
I checked them and at frist the place i got the tires from only had 50 psi in them. When i got them reblanced today i had them put 65 psi in them.that helped to get some of the rear sway out but not much.well at least i got the vibration out of them. I think if it does not cost to much more i am going to try a set of the toyo open country at tires.thanks mopar72
Mopar72
21
11-29-2007 10:08 PM
Nick660
04-27-2006 08:06 AM
