Are U Joints Covered Under 7/70?
Old 06-19-2009 | 07:18 PM
12PACK's Avatar
I think I have a bad u joint or something to that effect on my rear axle. There's a squeeking noise every tire rotation when backing. 33K on my 05, which was the last year for the 7/70.
Anyone know if this will be covered under the 7/70?
TIA.
Old 06-19-2009 | 10:45 PM
Spooler's Avatar
Yes, it should be covered due to it being a drivetrain part.
Old 06-20-2009 | 09:47 AM
12PACK's Avatar
Thanks, Spooner. I went to a dealer this morning and both my rear U joints have to be replaced. This will be covered by the 7/70 warranty, minus the $100 deductible.
They're even giving me a loaner, which surprised me as I didn't buy my truck there.
Old 06-24-2009 | 01:43 PM
yoda76's Avatar
Did you have any vibration @ highway speeds? I think my truck has the same problem. It sqeeks when I back up & hard vibration at 70-about 75 mph. Plus I have something clanking aroung when I'm towing at 65-70 mph.
Old 06-24-2009 | 01:57 PM
kokalit's Avatar
You might want to crawl under and inspect your hitch. There is a thread in the towing section with pictures of the factory installed hitch severely cracked where it is attached to the frame.
Old 06-24-2009 | 02:00 PM
12PACK's Avatar
Not yet. A mechanic friend of mine heard the sound when I was backing up and asked me the same question. I figured it was the u joints, but hadn't gone to the dealer yet, knowing it was probably covered under the 7/70.
Mine only squeeks when I back up, once every rotation. There's no odd sound going forward, or vibration.......yet.
I hope you have under 70K so if this is the same thing you have, it will also be covered.
I did some digging and it seems more owners are having problems with the front u joints, than the rear. I'll be listening for mine to start acting up, hopefully if they do, before my 7/70 is up. Glad I don't have an 06, with the newer grill, but only a 3/36.
Old 06-24-2009 | 02:26 PM
Jfaulkner's Avatar
Muted User
You can do whatever you want but rear u-joints are about $15 each (greasable). If you have your dealer replace them, pay the deductible, your still getting the same junk joints which you'll probably replace again in a few years (mine lasted about 35k). Or you could replace them with good joints and probably never touch them again.
Old 06-24-2009 | 11:46 PM
N.Johnson's Avatar
That is so true! But you got to think of the guys that can't wrench, no tools, space or experience. I can't understand why warranty is so important to some guys. Replace parts with the same type ie. ujoints, ball joints etc.
Old 06-25-2009 | 05:09 AM
12PACK's Avatar
I was thinking of doing just that, weather and time permitting. A friend of mine asked me if I wanted to borrow his vise.
Can't see how zerk free units are a technological breakthrough.
Old 06-25-2009 | 06:28 AM
trik396's Avatar
I destroyed my vice removing my u-joints. Wasn't as simple as I thought it'd be.
Old 06-25-2009 | 04:25 PM
Jfaulkner's Avatar
Muted User
I used a press on rear joints but when I did the fronts I just torched them in half and pressed the caps out.
You can rent a ball joint press from autozone It really is easy, I have all the tools but no motivation and I did it. I'd almost bet you could find a shop to replace all the rear joints with good ones for what the dealer will charge you with the deductible.
Old 06-25-2009 | 04:27 PM
Jfaulkner's Avatar
Muted User
I love the people who think the non-greasable joints are stonger. haha I'll bet my "weak" greasable joints are still better than the OEM joints with dust where the bearings should be.
Old 06-25-2009 | 04:31 PM
Out Back 4x4's Avatar
removing and installing them is not easy. i had the dealer replace both rears with spicer u joints and it cost me my deductible instead of 90 bucks a piece for them. took 4 hours for them to do it.
Old 06-26-2009 | 05:08 PM
Jfaulkner's Avatar
Muted User
What's your idea of easy, unscrewing the fuel cap?
I think if I can replace both front axle joints in just over an hr that's pretty easy. All 3 rear joints were about the same time but I actually pressed then all out. Hey if your dealer will install aftermarket joints for $90 go for it. But I wouldn't pay crap for the OEM joints.
Old 06-26-2009 | 05:21 PM
trik396's Avatar
something tells me that depending on where you live and how bad your winters are, will tell how long replacing these parts will take.
Quick Reply: Are U Joints Covered Under 7/70?
