U-joint repair has just turned VERY nasty
Old 12-18-2010 | 09:11 AM
Rednecktastic's Avatar
Sounds like he had a cruddy mechanic or supervisor. It's frustrating but he stood up for his company and work quality.
I bet if you send a tip to him covering the extra amount of the parts cost he'd never forget you.
Old 12-18-2010 | 11:30 AM
101st ABN's Avatar
I would send some cash also. Post the name of his shop too. Maybe at the least a bottle of something for the hollidays.....
Old 12-18-2010 | 06:10 PM
peckens's Avatar
kinda random and late, orilley charges $40 for the 464 ujoints and napa $60+
Old 12-18-2010 | 06:16 PM
Bark's Avatar
Originally Posted by willysrule
it works great
Forgot to thank you for answering my question. Thanks again. Wonder if anybody has pictures of the tool in use.
Old 12-18-2010 | 08:39 PM
willysrule's Avatar
found snap-ons guide for the tool...
http://image.snapon.com/international/pdf/dhp1_npa.pdf
Old 12-18-2010 | 08:49 PM
Bark's Avatar
Thats great!!! Im gonna get one. Thanks again.
Old 12-19-2010 | 10:23 AM
RollsCoal's Avatar
The Snap-On tool is probably the best way to go, considering the price. I did my first Unit bearing / U-joint / ball joint replacement on my 95 4x4 a few weeks ago. I was reluctant to use the power steering to push out the bearing, but I found that it was the best way to remove it. It initially sounded like a shady junkyard mechanic way to press out a bearing. I then realized, after almost using a slide hammer, that the power steering method applies all the load to the heavy bearing housing, and does not apply force to the actual rollers inside. If you use a slide hammer, you are basically hammering the rollers inside the bearing, and run the risks of damaging the bearing. I was able to piece together an extension, along with a socket, to fit between the bearing bolts and the axle. It worked perfectly.
yellowhemi
06-23-2011 11:06 AM
timcasbolt
02-02-2011 09:52 PM
RZinKY
03-05-2008 11:26 PM
Quick Reply: U-joint repair has just turned VERY nasty
