Two stroke Oil??????
Old 08-03-2008 | 09:35 AM
coparam4x4's Avatar
For us 3rd gen trucks, I think 1oz/gal is too much. I have cut mine down to
10oz/tank. Seems too run better at that ratio than 1oz/gal. But thats just my observation with my truck.
Old 08-03-2008 | 10:26 AM
NickBeek's Avatar
I found the same thing 1oz/gal (128:1) is too high for the 3rd gens, I lost mileage too. Try a lower ratio like 200:1. Right now I'm still experimenting with 300:1 but initial tests show me better at the 200:1. Time will tell.
Old 08-12-2008 | 11:47 AM
shonne's Avatar
Same here. The 200:1 seems really good for my 3rd Gen.
Old 08-13-2008 | 11:02 AM
dehunter12's Avatar
Ok gentlemen, if we needed to add 2 cycle oil to our trucks then why does it not state that in the owners manual? I think that you are all just asking for trouble in my opinion.
Old 08-13-2008 | 03:11 PM
Stovetop535's Avatar
I also saw a decrease in my mileage at 128:1. I actually stopped using it but ill try running some at 200 and 300:1 and see how it goes.
Old 08-14-2008 | 09:09 AM
DBLR's Avatar
I tried it out for several months and lost mileage every time I used it so I no longer use 2 cycle oil.
Old 10-06-2008 | 12:57 PM
levigarrett76's Avatar
Thats a big nono...EPA would not have it.
Old 10-06-2008 | 02:24 PM
SundayMoney's Avatar
I don't use 2 stroke either.
I will say,I'd be more inclined to use 2 stroke than the ATF a lot of old codgers still run in their diesel.
At least 2 stroke is designed to burn. ATF is designed to resist burning.
Old 10-06-2008 | 06:24 PM
2007 5.9's Avatar
I use 2-stroke oil every fill-up, been using it for last 3 months since the price of Bio has skyrocketed in my area. I use 1-16oz. every fill-up,MPG is the same and injector rattle is GONE.
Might go back to Bio, but not too sure yet. 2-stroke is WAY cheaper than Bio.
Old 10-06-2008 | 06:53 PM
haulin-rv's Avatar
I've ran it. I tried a quart to my 76 gallon aux tank and 2 quarts. Both ratios seemed to make it run a bit quieter and increase fuel economy about .5 mpg.
Old 10-06-2008 | 06:55 PM
no difference in economy for me...running either 16 or 32 oz
ive been running 16 oz per tank for the last 10000 miles, just quiets her down a bit and gives me piece of mind.
only time i dont run it is when i change my oil and dump 3 gallons of WMO in the tank
Old 10-06-2008 | 08:33 PM
glocklove's Avatar
I have been usin 2 stroke the last two tanks, I put 10oz for 34 gallons and 8oz for 32 gallons and saw 1 mpg gain on both tanks. The truck is a little quiter but not to much. The only thing I worry about is the injectors, so I am runnin some Lucas this tank just to keep the injectors clean.
Old 10-06-2008 | 08:57 PM
CamperAndy's Avatar
Not likely to make any real difference to fuel consumption at the ratios mentioned as there is little difference in the BTU content of two stroke oil to #2.
It can make a difference to the mechanical noise though.
Old 10-06-2008 | 09:36 PM
sallyman1's Avatar
would it be ok for me to run AMSOIL INTERCEPTOR 2 stroke sled oil? i think its ashless and its syntheic? or do i need mineral/petroleum based 2 stroke oil?
Old 10-08-2008 | 11:54 AM
DBLR's Avatar
Yes you can use it if you wish. I know of a person in northern MN who has used it for clso to 2 years now in his truck with out any problems.
Quick Reply: Two stroke Oil??????
