Turn key forward and LP primes up to 7 psi....
According to my quad LP gauge (i dont use rail anymore) when i turn key forward my LP sings until PSI is between 7-9 psi. Then i turn key backwards so i can just view the quad (no LP running) and i can see my numbers go 5, 4, 3, 2, 1 in about 5 seconds. Is it normal for fuel pressure to drop that fast before it gets to the CP3? obviously overnight itll drop off but why so fast and i cant see any leaks.
The fuel pump only primes, then cuts out when starting.
From what ive heard, its to prevent rough starting?
Either way, its normal. I put a fuel pressure guage in just to watch my stock LP till I get around to installing a walbro, and it does the same thing, turn key, goes to 6psi, then drops off to zero, and as soon as the truck is started jumps right back up.
I think power is being cut off to the guage for a few seconds while cranking the truck over and then recovers back to normal operation when truck is finally running. Just like the radio cuts out when being cranked over. Or I could just be full of myself and way off topic.
fireram
0
01-24-2013 10:19 AM
sallyman1
23
02-18-2009 09:46 AM
Tommy93w350
08-07-2007 12:15 PM
big red psd cc
12-29-2004 11:38 PM
