Turbo Oil Drain Line Gasket
I need to find the gasket for the oil drain line, that fits between the bottom of the turbo and the oil drain line mounting bracket/fitting!!!!!!!!!
Does anyone know the part number for this gasket?.....or does anyone know where I can find one ASAP!
My local Cummins center stated they cannot search for it, without a part number.....
Can I use RTV instead of the gasket or should I just buy a gasket sheet and make my own?
You could try calling a different cummins store to get the PN, then call your local cummins dealer back. A little more leg work, but you'll get the right part.
Tony
lu798welder
05-19-2010 06:12 PM
4969joes
03-12-2010 10:19 AM
Common
11-15-2009 10:05 PM
pistazie
ABDTR #5
04-30-2009 08:16 AM
