Turbo drain hose leak?
Old 03-19-2010 | 11:01 PM
txarrowhunter's Avatar
Driving down the road and when I parked my truck the whole bottom side of my truck was covered in oil. Looked for the leak and tracked it down to the turbo drain tube. It has one thin metal gasket and is on there pretty tight. But that's the source of the leak. Anybody now what might be the problem?
Thanks in advance.
Old 03-20-2010 | 06:09 AM
tlloyd's Avatar
Thanks in advance.
Which end is leaking? Is it the turbo end? If so there is a gasket. Or do you have a problem where the hose plugs into the oil pan?
Old 03-20-2010 | 04:37 PM
mq105's Avatar
Stock turbo? If you're sure it's leaking from the turbo drain at the turbo, the question is what disturbed/moved the drain to cause it to leak? It doesn't take a lot of force on the drain to cause a leak. (ask me how I know) I would want to know what caused it. Did you do some work recently and hit it, or is there another problem?
You can get a new gasket for $1 from any place that has cummins parts. #4931365.
Old 03-20-2010 | 05:08 PM
well iam about to do a turbo change anyway on it and im thinking it may have cracked were the hose meets the mounting plate. Havent really messed with it on my 07 so im thinking something must of hit it it cause yesterday i did pull a 3" branch out from in between my fuel tank and the frame.
whiskeyrichard
03-18-2009 04:10 AM
cootz
01-17-2009 09:42 PM
billmac
11-09-2008 02:33 PM
dzlfarmboy
10-18-2006 06:27 AM
george7941
08-10-2005 08:06 PM
