Turbo Cleaning
Turbo Cleaning
So I removed my silencer ring tonight after I got home from work. While it was apart I decided to inspect the turbo a little. There was no appreciable play in the compressor wheel, axial or radial, and the blades were all smooth, but the blades are dirty. I think it is brake dust that has gone through the factory filter. I wiped them clean as best I could with a lint free shop towel moistened with a little water. I was thinking though, we used to wash jet engines out in the Navy by spraying water into them while they were running. I wonder if a person was to get a clean spray bottle with water in it and start the truck with the intake removed and spray some water in the inlet if that would cause any issues? Before I get flamed, I didn't do that, but I am considering it. Thoughts?
BTW the truck has 78K miles on her.
I don't think the residue (spelling) really effects it. I see what you're saying about a spray bottle. It probably won't hurt it. But will it throw a code?
Nope, only the stock Mopar filter, ever. I change them way before they are very dirty too. I am on my 5th or 6th filter in 78K miles and she is a pavement queen. My right front brake makes a LOT of dust and the factory intake gets it's air from that fender.
You would have no issues squirting water at the compressor while running. Fired wash on a jet engine uses straight water or a water Diesel (JP-5) mix.
Personally I would use a soak wash method. Just wash/spray the compressor with a degreaser, let soak then rinse. If it is still dirty then do it again. Once it is clean enough then start the truck to make sure it is dry.
A word of warning is do not flood the intake to the point you get standing water past the turbo.
My turbo looks the same way,dry black dust on the fins. I change my filter sooner than recommended too. I also use the stock filter. I think if some of you guys went and pulled the tube off of your turbo you'de find the same black dust. My truck has 30,000 miles,I noticed the black fins at about 10,000 miles. I don't think they make a filter that stops EVERYTHING.
To answer the question,I'm not sure about spraying it with water.
If you are getting that kind of dirt past a stock filter, you might want t check your intake for leaks. Dirt like that can be fairly common with some of the after market filters, but it shouldn't be happening with a stock filter.
The dust that several like myself have seen is smaller than the filter can catch. If you had a filter that could stop it you would have greatly reduced air flow. Next time I open up the intake I will water wash it and let you all know how it works out.
BTW, the silencer ring doesn't really change the sound with a stock intake.
