Turbo Bark
Old 10-02-2010 | 07:56 PM
slickr1's Avatar
Turbo Bark
Can anyone enlighten me to what causes turbo bark? and should I be concerned if my truck did have a small turbo bark?? I pulled from a stop sign and saw some wet pavement, well I had to mash the right pedal. When I was done sliding side ways I let off and the turbo barked several times..
Old 10-03-2010 | 12:36 AM
bonus's Avatar
LOL,,,, you masher you. sliding sideways edit
Old 10-03-2010 | 08:00 AM
Hvytrkmech's Avatar
Turbo bark is excess pressure being rapidly released back through the intake, not good on these engines. A VGT turbo without a waste gate is designed to do that, but not a turbo with a waste gate. Is you waste gate turned off or disabled?
Old 10-03-2010 | 08:40 AM
slickr1's Avatar
Bark
Hvy, as far as I know the wast gate is operational. Turbo is stock. How can I tell if it is working??
Old 10-03-2010 | 08:55 AM
Hvytrkmech's Avatar
Do you have a boost gauge?
Old 10-03-2010 | 05:10 PM
Blueboy's Avatar
If you let off pedal easy after hard run, it won't bark.
Old 10-03-2010 | 05:31 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Turbo bark = Dead Turbo...... Don't do it!
Old 10-03-2010 | 05:36 PM
slickr1's Avatar
bark
No I do not have a boost gauge. I have done this before just spinning the tires and have never had a problem. I did in fact have to let of rather guickley though.
Old 10-05-2010 | 04:35 PM
Shagginwagon's Avatar
From what I've been told, it is a more common occurance with upgraded transmissions. I never had turbo bark until I got my DTT installed. Is it bad for the turbo? ---yeah. But like said above, let off the throttle more easy and it won't do it. My turbo barks when I go into lock up. So I lock out OD until my RPMs are high enough that it won't cause the turbo to bark. Then OD on.
TDIwyse
15
12-06-2008 11:19 AM
OldRam
02-16-2006 06:41 AM
MKELLY
10-15-2005 10:15 AM
pwrtripls1
06-25-2005 09:38 AM
gatf4
18
05-31-2005 04:31 PM
Quick Reply: Turbo Bark
