Truck won't stay running
Old 05-28-2011 | 09:38 PM
exwrestler's Avatar
I go to start my truck and it starts for 2 seconds and then dies. This happens again and again what's wrong
Old 05-28-2011 | 10:21 PM
BigIron70's Avatar
Cummins Guru
Maybe bad FOB key, try another key. You can pull the IOD fuse and wait ten minutes push the fuse back in. Resets the WCM module. If the PCM/ECM receives an invalid key message, or receives no message from the SKREEM over the CAN data bus, the engine will be disabled after about two seconds of operation. The ElectroMechanical Instrument Cluster (EMIC) (also known as the Cab Compartment Node/CCN) will also respond to the invalid key message on the CAN data bus by flashing the security indicator ON and OFF.
Old 05-28-2011 | 10:23 PM
exwrestler's Avatar
Tried both keys no luck.
Old 05-28-2011 | 10:33 PM
BigIron70's Avatar
Cummins Guru
Try disconnecting both battery for ten minutes. Disconnect ground cable on the batterys. Make sure ignition key is off when doing that. That will reset the WCM.
Old 05-28-2011 | 10:52 PM
exwrestler's Avatar
Can it be caused by the factory security?
dkenny
21
12-30-2014 09:04 AM
snakefarmer
12-15-2008 02:28 PM
modrod
02-05-2007 11:18 PM
Cam73
11-07-2006 12:38 PM
JRS240
01-29-2004 08:06 PM
Quick Reply: Truck won't stay running
