Truck is up and running but egt's are high.
Old 07-12-2007 | 09:59 PM
CG98x's Avatar
Alright I got the head on my truck yesterday and everything went well. it didn't even smoke on start up. However my cruising egt's are higher now and with a slight hill even set to stock I see over 1000' F. I did change my tires while it was down and I went from 265 AT to 305 MT. I don't think this would cause my symptoms, but I don't know. Cruising at 70 my egt's run 850-900 this is what I used to run pulling. Boost is the same as before, turbo sounds the same and the truck runs fine, but it just doesn't seem right.
Old 07-12-2007 | 10:31 PM
OOPS's Avatar
You are pulling a taller gear with the bigger tires making the engine work a bit harder.
Old 07-12-2007 | 10:45 PM
dodgezilla04's Avatar
^^^^^^^^^^yep. that is a significant tire size change.
Old 07-13-2007 | 06:37 AM
CG98x's Avatar
I hope that is all it is because right now I'm kind of paranoid since I just got this thing back together.
snakefarmer
12-15-2008 02:28 PM
mopar440cu
18
10-10-2007 08:37 PM
jmccart
03-18-2007 10:03 PM
Dave88LX
35
12-07-2006 05:49 PM
jmccart
14
11-20-2006 06:45 PM
Quick Reply: Truck is up and running but egt's are high.
