Truck skips when wet. Cam sensor code.
Whenever it rains my truck just about will not run and throws a cam sensor code. Have checked the wiring. Found nothing wrong. Greased the cam sensor fitting. Put some water on the drivers side of the block and truck wants to quit. Had a quadzilla box plugged in for a while. Wonder if need to re grease those fittings. Passenger side is not getting wet when we do this so I cannot see it being the wiring by the compressor. Any ideas?
Think we found the issue. Wire on the top of the backend of the motor seemed loose. Not totally unplugged but not quite right either. Fixed it and have run water on it for two days with no skip. I have my fingers crossed. No idea how this would get loose.
Usta HaveA Hemi
08-30-2005 06:44 PM
