Truck revs but wont change at all
Truck revs but wont change at all/p0148 repeating
while driving trucks goes thru 1st 2nd and 3rd fine under normal acceleration however if i walk on it the truck just revs and will not change if i slowly ease up on the pedal you can feel her shifting, but not to final gears i can walk on it and goes nowhere just goes to 2500 rpm and stays there will not shift ?? any ideas folks just changed out speed sensor and gov press sensor new fluid right level, this was happening before i changed the 2 out so i have no clue what problem is hopefully someone here can give me so info
thanks in advance
cory gale
also when i walk on it itthrows hpcr code p 0148 i clear it then try it again every time i shove he to the floor it throws that code
any info is appreciated
thanks in advance
cory gale
know what the code is im lookin for a suggestion on what is causing it and the what is causing the symptoms pretty sure its fuel problem just lookin for a direction to look.
thanks for the reply
corygale
thread at bottom of page is for code no symptoms thats not what i got
corygale
You may want to try the transducer also. I just changed the same 2 electronics and the parts guy told me when they change the solenoid they always change the transducer as well. He said they run hand in hand. If memory serves correct i believe it was only $75 or so. Cheapest attempt next to a fuel pressure gauge to see what the lift pump is doing. IMO
thanks im thinkin its all fuel system now and not tranny problems the truuck isnt even revin high as it normally would and now almost hesitates a fraction of a second before reving when i walk on it gotta figure this out its killin me
Dan_K
01-20-2010 08:34 PM
06CTDforAU
10-01-2008 05:53 PM
roughstock
08-10-2008 11:51 AM
twisselman1968
32
07-22-2008 09:43 PM
