Truck lunging or surging
Old 07-29-2009 | 09:58 AM
tauberson's Avatar
I searched and did not find any information. Twice now, once in the morning after setting over night and once while sitting all day I have noticed a lunging or surge fealing when driving low speed just before trans shifts into second. I thought at first it was trans. My buddy who has trans shop said if it was i should have noticed RPM racing. I don't remember if they did, but I do know engine noise did not increase. He said it could be TPS. Anyone have any ideas ?
Old 07-29-2009 | 10:09 AM
tesla440's Avatar
It could be the 2-3 shuffle shift issue that is common. Do a search for the govener solenoid. I believe that there is a TSB out for this issue. It's a simple fix. In fact a few I've replaced the govener solenoid with that from a GM (www dot transmissioncenter dot net/dodge dot htm).
Old 07-29-2009 | 09:50 PM
dirtygoat's Avatar
TSB 21-009-07 - Governor Pressure Solenoid -
I had one replaced at 31k, truck just hit 99k the other day and I think the same issue is coming up again.
Old 08-15-2009 | 12:02 PM
tytimbers's Avatar
surge
check the o ring on the map sensor , my o6 qc had a tear and
was causing a surge under light throttle, and also a knock at idle after engine
warms up. hope this helps
estesbubba
09-23-2011 10:29 AM
Timothy Rau
01-31-2007 09:00 AM
Bad Ramer Jamer
12-30-2005 07:52 AM
silverram323
05-03-2004 09:02 PM
tankeryanker
02-14-2004 10:30 PM
Quick Reply: Truck lunging or surging
