Truck has issues after installing new fuel injectors
Hey, I just had some new fuel injectors installed in my 05 dodge. Sisnce then, I have had som issues with the truck stalling. It happens at random times. Is this something that is expected with new injectors?
No something is wrong
I would take it back to where you got the work done
Most common problem with CR injector install is not torquing the connector tubes properly.
What estrada said. A friend had issues after installing his injectors. It turned out that the connector tubes needed to be torqued a little tighter then the book calls for.
sledneck1
13
01-29-2008 12:38 AM
