Truck Eating Water....
Old 12-16-2009 | 01:39 PM
05CTDN8's Avatar
I hate to say it....because i am a glass half empty guy. But I feel there is a good chance you are a candidate for another blown gasket. You could be good at idle and when the boost starts to build you are feeding the cylinder with a mist of water. It wont smoke like the truely blown head gasket...white smoke generator type....but that is just my 2 cents.
Old 12-16-2009 | 01:45 PM
soulezoo's Avatar
DTR 1st Sergeant
I have a feeling you are correct; however, I just can't accept that yet! The engine hasn't seen over 12psi of boost! But the water has to be going somewhere, right? XLR8R said I now have bragging rights to largest homemade water injection system...
Take that Mr. John P.!!(AKA Mr. Water Injection) J/K...
It is frustrating though to have put on 3 gaskets and not solved problems... you know how much work goes into changing one of those things on my truck??
Old 12-16-2009 | 02:24 PM
Mr Jerry's Avatar
My bet is its not a headgasket, can you smell anything sweet when you run your heater in the truck?
Floor mats wet?
Might have been a headgasket 1st time, but I bet its not this time.
Old 12-16-2009 | 02:28 PM
Spooler's Avatar
Well only one thing to do if you can't find the leak. Off with the head again...
Old 12-16-2009 | 02:33 PM
Mr Jerry's Avatar
If it was me with this problem, I would be pulling the T-state out, and refilling the system from the upper radiator hose, then driving it a day to see what happens then, just make sure your cooling the radiator down before your pulling the cap everytime, if its building pressure in the radiator after you cool it down, then chances are it could be a headgasket.
Old 12-16-2009 | 03:17 PM
soulezoo's Avatar
DTR 1st Sergeant
Floor mats wet?
No sweet smell inside or from exhaust... and I run the heater all the time!
Old 12-16-2009 | 03:19 PM
soulezoo's Avatar
DTR 1st Sergeant
Just so happens I've decided to try that fancy "headgasket repair" stuff... and see what happens. $20 vs $1000....
Old 12-16-2009 | 04:04 PM
cbrahs's Avatar
that stuff is like using a piece of bubble gum on a waterdam leak. with the boost numbers you are capable of running, it won't last long
Old 12-16-2009 | 04:26 PM
soulezoo's Avatar
DTR 1st Sergeant
^^^^ I totally agree... but I have to drive this for now and don't have down time for it... again... to figure it out correctly. Maybe after tax return time.
Old 03-04-2010 | 07:32 PM
JRK's Avatar
JRK
Just to update this, turns out the rear freeze plug in the block was leaking, but would only do it about 200 rpms and up. Thats why there were no visible leaks idling but it was eating water like mad. He had a Haisley freeze plug kit installed and so far all is well.
Old 03-04-2010 | 07:57 PM
madhat's Avatar
Administrator/Jarhead
Awesome. I was going to suggest some blacklite dye, but it's fixed.
hamilton71801
05-21-2010 07:57 PM
c_nelson99
06-20-2008 01:01 PM
Jeff in TD
13
06-22-2004 03:24 PM
Quick Reply: Truck Eating Water....
