transmission service
Old 09-02-2010 | 06:13 PM
James Birdsong's Avatar
Question transmission service
I'm about to service my 48re trans, then replacing the pan with the larger replacement from MagHytec. Is there anything I should be aware of other than keeping it clean, using ATS +4 fluid (6-7 quarts, then an added 4 quarts for the larger pan)? How about adjusting the bands? Any thougts, thanks in advance.
Old 09-02-2010 | 07:39 PM
TexasCTD's Avatar
Make sure you replace the Transmission Filter with a new one. Actually, your new MH pan will have a piece to lower the filter down lower into the sump.
If you trans has been working fine, you don't need to adjust anything.
steelblitzkrieg
10-14-2011 09:19 PM
dieselbeef
06-12-2006 08:12 AM
SOhappy
34
03-04-2006 04:16 AM
lawnman757
03-27-2005 12:12 PM
bigdogtruck
08-24-2004 06:05 AM
Quick Reply: transmission service
