Transmission Service
Old 07-22-2008 | 11:28 PM
woodrep's Avatar
Did you measure how much came out? I am not sure if you dropped fluid when low if someplace else in the system would allow the transmission to be able to take on more than 7 or 8+ quarts. VZDude might have some more insight on this one.
Old 07-28-2008 | 02:22 PM
SOhappy's Avatar
Originally Posted by mjsandt
...and was wondering how much fluid to buy? I have heard 4 quarts, 6 quarts and 7 quarts. ...
MSandt
Like everyone said, get 8 just to be on the safe side, but for my 60k service I'm doing a total fluid exchange, which requires 16 qts.
This thread will help:
https://www.dieseltruckresource.com/...ghlight=tranny
BTW, how many of you guys dump the old ATF back in the fuel tank? And at what ratio? Do you filter it first?
Old 07-28-2008 | 10:11 PM
woodrep's Avatar
I absolutely won't dump ATF in my fuel tank. I've read enough about dragging lubricity out of fuel which we need now.
Old 10-19-2008 | 11:43 AM
tt433's Avatar
Dose anyone know if the stock converter has a drain plug in it? And if so how much trans fluid is needed to change it?
Old 10-19-2008 | 12:43 PM
torquefan's Avatar
No, unfortunately they don't put in a drainplug. To flush the converter, I usually fill the trans with fresh fluid, then disconnect a cooler line, start the engine in neutral and let it pump the fluid out the cooler line, through a hose and into a drain pan. It's an art, and it takes a few tries to do it successfully and not have to clean ATF off your neighbor's roof.
Old 10-19-2008 | 12:47 PM
torquefan's Avatar
Originally Posted by dozer12216
Band adjustment is necessary. Without band adjustment you eventually lose second gear or reverse gear. When you run out of adjustment threads the KD band is worn out.
Like bigIrons suggestion.
I agree that it's very necessary. I have stumbled onto several of these transmissions that have a very loose band on the first service. After adjustment, it never seems to get loose again. This leaves me to assume that some never get the proper adjustment at the factory.
Old 10-19-2008 | 05:54 PM
dozer12216's Avatar
2003RAM
Yes! Really !!!!!!!!!!!!!!!!!!!!!!
Old 10-19-2008 | 06:11 PM
annabelle's Avatar
Leave the band adjustment to the experts. I've got 211,000 plus on my 04 and haven't touched the bands. Necessary.......NO.
Old 10-19-2008 | 11:40 PM
alboy's Avatar
I thought mine shifted decent ,then i did the band adj and service myself at 35000 miles,it has never shifted as crisp as it does now,i don,t think it was ever adj correctly from the factory.
Old 10-20-2008 | 09:38 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
while you got your pan off... be creative and braze in a drain plug assembly. It'll make changing the fluid next time easier...
steelblitzkrieg
10-14-2011 09:19 PM
dieselbeef
06-12-2006 08:12 AM
SOhappy
34
03-04-2006 04:16 AM
lawnman757
03-27-2005 12:12 PM
bigdogtruck
08-24-2004 06:05 AM
Quick Reply: Transmission Service
