Transmission Service
I am getting ready to reach 30K miles and was wondering if the service should be performed by a dealer to have the bands readjusted, or should I take it to a transmission shop to have this done.
Either way I go, does anyone have suggestion for the North Houston or Conroe area for a dealer or transmission service shop?
Thanks.
Thanks.
Some say to adjust them at every service but I was told to only do so only if it starts to slip. When I had mine serviced at 10K my dealer told me being I drive mostly Hwy miles I could go a lot longer then a person who does mostly stop and go city driving. Just make sure if you go to a trans shop that they only install ATF+4 fluid and not AFT+3 that I've seen some do. If you got the $$$ install synthetic AFT+4 as it will hold up better. Oh and don't let them tell you normal ATF+4 is synthetic as it is still a group III fluid that is close to synthetic but its still not as good as full synthetic trans fluid that is made from group IV base stock.
JMHO
JMHO
SOhappy
34
03-04-2006 04:16 AM
