Transmission Relay?
Old 08-23-2011 | 03:59 PM
Roadmedic's Avatar
Transmission Relay?
I just got the limp mode on the famous trio codes.
P0882
P0973
P2769
Just had the governor solenoid and transducer changed Friday. Probably less than 100 miles since.
Today it failed to down shift and set off the cel light and put me in limp mode.
My scanner from Matco would remove the code, but as soon as the key is used to start it is back.
Research tells me to check out all of wiring. They are all snug, did not unplug.
Research said to check the transmission relay. Where might it be located?
2007 Dodge 5.9 automatic all stock.
mazeppa
02-10-2004 06:54 PM
Maccandy
06-02-2003 08:30 PM
Jack Thorpe
04-18-2003 01:26 PM
Neal C.
01-12-2003 11:08 AM
tomsauto
12-28-2002 08:57 AM
Quick Reply: Transmission Relay?
