transfer case shift motor FUBARRED
Old 02-20-2008 | 07:06 AM
abc4yew's Avatar
Guys, Anybody got a spare motor to shift on the transfer case. I can't always get 4 hi and if I do then I can't always get back...if you have everything I need to get to 4wd with a manual lever and it will work...I'd rather that....Help!!! Kerry
Old 02-20-2008 | 11:36 AM
05mxdiesel's Avatar
I thought I remember reading it was virtually impossible to go from electric to manual due to the case design. Rockauto has reman units for $88
Old 02-20-2008 | 10:12 PM
abc4yew's Avatar
Hey thanks....I found a $114 Dorman part....no rebuild.....found some good prices on unit bearings also...They wanted $350 for a rebuild motor here...yikes, Kerry
Old 02-21-2008 | 12:24 AM
UnrealTrendz_OR's Avatar
when i traded in my last 05 for this one that was the one and only thing i hated was the elect TC shifter, the manual atleast you know its in, ive had problems with mine doing the same, even had it back to the dealer.
Old 02-21-2008 | 04:02 PM
abc4yew's Avatar
Yep, My regular cab has the manual shift and hopefully my next play truck will too. Kerry
Old 02-21-2008 | 04:14 PM
enafzige's Avatar
I had mine replaced under warranty at about 2,500 miles.
Hopefully you'll be good to go with the new unit. I read somewhere here, that you can't directly convert an electric design to the manual, as the whole transfer case is different.
--Eric
Old 03-01-2008 | 11:07 AM
abc4yew's Avatar
Got stuck the other day and had to use 4wd so I clicked the switch and it worked perfect...came out easy also...I've used it a dozen times since...glitch in the works I think. Kerry
twindoo
07-25-2011 10:00 AM
Motorama
12-01-2008 12:03 PM
Nicholas
12-24-2002 06:02 AM
Quick Reply: transfer case shift motor FUBARRED
