Transfer case seal leak?
Old 05-21-2009 | 07:00 PM
BADBOWTIE's Avatar
OK the output seal on my t case is leaking. What is involved in changing this seal. I do not have a garage but do have a decent amount of tools. Can I do this in my driveway? Any brand of seal I should get? Thanks Jason
Old 05-21-2009 | 10:46 PM
Swarthy Dago's Avatar
take off the drive shaft from the rear end at the yoke, four small bolts, pull out of the transfer case, pry out the seal, go to dealer for the part, intall it by using a large socket or piece of wood between it and the hammer. That seal might have a small 1/16 inch hole, a weep hole, make sure its at the bottom so moisture can drain out, before installing the seal make sure the shaft that it rides on is nice and clean and polished. takes less than an hour in your driveway
Old 05-23-2009 | 02:17 PM
BADBOWTIE's Avatar
great info thanks
sallyman1
06-26-2009 09:15 AM
Lightman
16
01-21-2004 10:46 PM
DEC
09-29-2003 09:47 AM
DEC
09-26-2003 08:29 PM
Quick Reply: Transfer case seal leak?
