Transfer case rear leak?
Old 09-28-2010 | 05:29 PM
VaultRam's Avatar
I've read of people's transfer cases leaking at the rear and now mine is doing it. Just wondering if I should put a new transfer case rear output shaft seal in or transfer case rear seal in. Thanks for the input!!
Old 09-28-2010 | 07:07 PM
ckster's Avatar
Check the yoke on your driveshaft. I recently repaired mine and that was where it was leaking.
Old 09-28-2010 | 08:30 PM
VaultRam's Avatar
I really haven't inspected it closely but it looks like it's leaking before the yoke. There's oil all over the rubber boot so I think it's one of the seals I mentioned above. Maybe I'll do both seals since they're only $20 a piece from my local napa store.
Old 09-28-2010 | 10:00 PM
ckster's Avatar
Check this repair, this exactly what was wrong with mine. I replaced the dust boot first and had no luck.
https://www.dieseltruckresource.com/...sfer+case+leak
Old 09-28-2010 | 10:40 PM
VaultRam's Avatar
Did you JB weld the cap back on or use the RTV like him? Also I had the dealer do the rear u joints a little over a year ago and I think they replaced the yoke cause it was leaking but I can't remember for sure. Guess the next time I get some free time I'll tear it down and see where it's leaking.
Old 09-29-2010 | 07:02 PM
ckster's Avatar
I tried the jb weld way first....no joy. So I took it apart again and used black rtv I believe. So far so good.
wyododge
08-18-2011 07:48 AM
swordfish
06-01-2010 04:07 PM
Lightman
16
01-21-2004 10:46 PM
blh1960
10-07-2003 07:29 AM
Quick Reply: Transfer case rear leak?
