Transfer Case how much oil?
Old 01-20-2008 | 10:05 PM
3500CTD's Avatar
Originally Posted by Nate-03 D
Maybe someone can chime some info in on this.
From what I understand the fluid in the T-Case is only beeing "used" when 4wd is engaged?
No, I dont think so...Im pretty sure the fluid is cooling the bearings in there even in 2 since the power is still being run through the t case.
Old 01-20-2008 | 10:16 PM
bansh-eman's Avatar
i dont think so, the tranny is still using the transfer cse for the rear wheels and when you engage 4x4 then it turns the front as well..
Old 01-20-2008 | 10:21 PM
Nate-03 D's Avatar
Thanks for clearing that up. I spose I better pick up some ATF.
Old 01-21-2008 | 01:52 PM
DBLR's Avatar
You guys who posted 15,000 mile change out made be go outside to the truck and get my owners manual as I thought it was longer then that. BTW its snowing an 8 degrees outside right now! Anyway my 2006 owners manual shows to change the transfer case out at 60,000 mile for sever service and 120,000 miles for normal service. I noticed that Amsoil claims there ATF will hold up for 50,000 miles for sever service in a transmission so how long will it hold up in the transfer case?
wyododge
08-18-2011 07:48 AM
bradler
03-19-2010 09:49 PM
RedRacer44
06-21-2007 12:07 PM
Gordonville
14
02-27-2004 07:16 PM
Quick Reply: Transfer Case how much oil?
