Transfer case fluid change, help... pic included
Old 04-14-2010 | 06:14 PM
Shorts's Avatar
How disappointing. I undid the fill hole and dipped my finger in there only to find fresh fluid. I was all eager to put new fluid in. The plug was also nice and easy to remove too.
Well, I have bottles of ATF+4 on the shelf now
Old 04-14-2010 | 07:24 PM
Dr.Dizzle's Avatar
You could use it to flush/replace the power steering fluid.
Old 04-14-2010 | 07:26 PM
madhat's Avatar
Administrator/Jarhead
^^^ Yep!
Old 04-14-2010 | 09:18 PM
bansh-eman's Avatar
Or better yet, you could use it to flush mine!!!!
Old 04-14-2010 | 10:41 PM
Shorts's Avatar
haha I thought about doing the steering. That fluid checked out good too! Though not a clue if it is synthetic or not. So probably worth a flush.
Oh, incidentally I did see the rear seal/boot there on the tcase tail was in real bad shape. It was cracked all the way around. It looked like dry rot like tires get. When I reached up to feel it the perforated cracks tore. Is this going to be a pain in the butt?
Old 04-15-2010 | 01:25 PM
justin allan's Avatar
I checked my front dif fluid about 1 month ago it was over full and the fluid color looked like a dark 2% white milk color. Not sure how water got in there my truck has never been submerged in water even close to front dif. anyway took cover off and cleaned housing good with break clean and reasemble. I always check the rear because it does 95% off the work. I will be checking front diff more offten from now on!
Old 04-15-2010 | 02:19 PM
Shorts's Avatar
The front doff fluid on my last truck looked like a brownish-gray chocolate milkshake
I wonder if condensation plays a part inside the diff for temp changes and normal degradation of the fluid? Since many of us state that the axles weren't immersed.
Old 04-15-2010 | 02:49 PM
purduepurdy's Avatar
Can't remember if these trucks have it or not but do they have a breather that runs up under the hood. Might just make sure the breather cap is ok if there is one.
Old 04-16-2010 | 12:40 PM
ssandlin's Avatar
My 06 has the breather tube.
Bookmaker
05-19-2007 08:11 PM
030303
03-29-2005 04:16 PM
Jones0027
10-29-2003 01:41 PM
Commatoze
16
09-23-2003 11:15 PM
Quick Reply: Transfer case fluid change, help... pic included
