Trans temp of 250 degrees?
Hit it this weekend towing my 6,500 lb 5th wheel for a short period. Couldnt pull over... once over the pass is dropped immediately. Seems high to me. Should I be concerned? Trans doesnt do antyhing weird shifts firmly doesnt slip. Truck is stock except for BFG's. 40k miles
Anyone out there tell me something similar for them? Is this normal or excessive for a Dodge?
Do I or can I do anything about this?
Do these trucks have a Trans fan?
Thanks
Thanks
You may want to consider a aux cooler... .and sometimes it's not just weight but wind resistance, also the 35's aren't helping....
I agree but my 5ver is small at 26ft and is not the extra height up front type, like a lot of guys drag around.
I agree the 35's aren't helping. I will jack the trailer up tonight to see if I have a dragging brake.
Well your sender is in the correct spot.... And to be honest I have seen very few rigs, if any, that come with what I would consider adequate transmission cooling. So an aux cooler may be on the horizon...
IMO you shouldn't tow any real distance with the TC unlocked. That may mean installing a lock-up switch or a fancy controller like the ATS Co-Pilot.
Mine couldn't run any cooler that it already does. Towing 8-14k lbs at highway speeds with 500-600hp I only see 145-165* (that's in the hot line). Empty it runs 135-145*.
Definitely sounds like you may need a converter/VB. With the big tires and any kind of towing and decent power you are likely slipping the TC and heating it up. A good TC/VB from Goerend or the like will dramatically drop the temps and probably increase your mileage as well. Doing these sooner rather than later will help the guts of the tranny last a lot longer also.
I have extended powertrain warranty on the truck. Think if I brought it in they would be able to diagnose a slipping TC and possibly replace?
Wouldnt I notice a slipping TC while driving especially w/ weight behind it?
Done lots of things but toasting a TC is not on that list.
Aux coolers are NOT reccomended on any of these transmissions unless you use a seperate pump to do it. The cooler return line is trans lube and changing its characteristics is not a good idea.
Question for original poster; how fast were you going and was the TC locking? You should be able to easily tell the difference between lockup and no lockup by the rpm drop.
Tow/Haul prior to 05 was an OD lockout. Did you use that or leave it OD?
Factory cooling on all the Doge trucks has been good since the 2nd series. Take a look at the cooler sometime and you will see.
Will a Dodge shop be able to address my concerns about this or will they just roll their eyes? Like I said I have extended powertrain.
TC should be locked at 40+mph with the tow/haul feature on. Are you sure the TC was locked? Could be the issue. I never see over 200* towing my 8klb travel trailer in the summer, even on steep hills.
I have a Double Deep Aluminum pan. (Aluminum conducts heat 3 times better then steel, so yes, it does aid in cooling) and 315/75/17 tires with 3.73 gears.
Tow haul was activated. Approx 40-45mph snow was really starting to come down and my speed was dictated by the folks in front of me. Like I have said I had no options to pull over otherwise I would have. Hate to see what would have happened if it werent 32-34 degrees!
I would take it to dealer and tell them the TC clutch isn't working right and see if thery can find an issue.
