trans shifting prob
Old 08-30-2007 | 10:53 PM
vzdude's Avatar
DTR's 'Go to Guy'
Originally Posted by isbeinside
if that were the case and the anchor came of the front band then you would never have second gear!?!
These linkages are on the outside of the trans. Driver's side of the case where the cables hook up.
Old 08-30-2007 | 11:37 PM
isbeinside's Avatar
my bad i was refering to the anchor inside the trans on the front band
Old 09-01-2007 | 09:27 PM
bziggy's Avatar
I would still say it sounds like a v/b problem. The only other thing i would still say is to check the pressuer in the trans at the test ports and make sure you have the correct pressuer. If you have any internal leaks it will cause nothing but problems with shifting. Good luck
Old 10-26-2007 | 04:41 PM
fast_enough's Avatar
Angry 2003 HO Owners
Originally Posted by mjsandt
Mine does the same thing, I have been searching for an answer, and nothing yet. Hopefully we can figure this out, because this sucks!
M Sandt
It seems to be a problem with most of us 2003 HO owners. I have changed the speed sensor,pressure switch and sensor and still does it. What is strange is that it just started a few weeks ago at 93,000 miles. It is driving me crazy. I dont know where to go now. I hate to take it to the steelership .
Old 10-26-2007 | 05:14 PM
Hopper's Avatar
Just don't let the problem go to far. Mine started in the high 90's a few months ago. I'm at 110k now. The problem will extend through all your gears eventually, followed by a mild vibration in the drivetrain - starting around 55mph. Now my truck vibrates so bad, even at low speeds, I'm afraid it won't make it to the end of the block before the tranny drops out. It clears up a little after 5 miles, but not a good thing to be driving.
Most of the time I can't get the truck into 3rd gear unless I can run consistantly at 2700 rpm for 5 seconds or so. Then it will shift into 3rd, but If I reduce speed at all, it will immediately drop back into second.
The severe driveline vibrations will rattle through the transfer case and destroy the seals, followed by the differentials and u-joints.
Only reason I let mine go so long is because I wasn't getting paid. I've contacted Goerend about getting the tranny redone (or replaced as it may). Just waiting to hear back from them. I'm probably looking at a conservative $7k just to get the driveline back in proper order.
Just my $.02, but get it taken care of now. It can cost you more down the road.
sluketic
08-29-2007 03:04 PM
BuckeyeRed
10-17-2006 10:44 PM
rentalguy
11-29-2005 07:09 AM
Superduty12v
12-02-2003 11:55 AM
Quick Reply: trans shifting prob
