Trans pan gasket
Old 03-08-2005 | 12:49 PM
What a load's Avatar
Trans pan gasket
Need some advice. I plan on putting in my 3 gages for monitoring my Boost, Exhaust and Trans temp. The company I purchased them from sent instructions on how to mount the Trans prob. I need to take the pan off and drill a hole in the side of it and replace the pan and oil. My question is should I use an ordinary gasket for the auto store or is there liquid type out there I should be using to make sure I don't get a leak.
Any advice on installing these 3 gages would be welcomed.
Thanks
Old 03-08-2005 | 01:10 PM
TRAVIST's Avatar
The factory gasket is a plastic frame with an o-ring impregnatedinto it. You can reuse them or just replace them but I would use the chrysler gasket either way. just my $.02
davelinde's Avatar
I use the factory sendor for trans temp. But...
Which trans do you have? On the 48RE the gasket is absolutely re-usable.
Drop the pan then re-install. Just did it last weekend myself.
Old 03-08-2005 | 08:04 PM
Dodgezilla's Avatar
I've had my pan off about 4 times and have just wiped down and reused the factory gasket with absolutely no leaks!!!!
Old 03-08-2005 | 08:45 PM
Boss Hoss 540's Avatar
Re-use the factory gasket I did last week when I installed the ATS Pan which BTW holds 5 more quarts and already has the hole tapped for the sender.
Old 03-08-2005 | 11:19 PM
03CTDCO's Avatar
Like everyone else has said, re-use the factory gasket. I replaced my pan with a +2 qts PML
trans pan 3 weeks ago. See my Gallery for photos. I also installed my gauges and those pics
are there to see also.
Old 03-09-2005 | 07:47 PM
gsbrockman's Avatar
How difficult is it to install the sensor in the cooler line from the transmission to the cooler? Seems as if I've read previous posts about this and I was under the assumption the cooler line was the best/most accurate place to install the sensor.
Greg
Hunter11
10-06-2009 06:20 PM
scow1
06-01-2009 12:19 AM
tufamc
05-05-2007 08:36 AM
TIM RYDEN
12-23-2005 03:43 PM
redramnc
12-16-2004 08:53 AM
Quick Reply: Trans pan gasket
