Trans Clutch Disks - How do I know how much is left?
Old 09-05-2010 | 05:08 PM
nvr-enuf's Avatar
Hello everyone, I have a 48RE - How do I know how much meat I have left on my trans clutch disks before they are metal on metal? Seems like a simple question - is there a simple answer?
Thanks
SAS
Old 09-06-2010 | 08:46 AM
nvr-enuf's Avatar
Bump
Anyone? Must be someway to figure out.
What about the band adjustment?
If the valve body was removed, can you see the clutch packs?
Old 09-06-2010 | 11:21 AM
2007 5.9's Avatar
Only way too see clutch wear is to dis assemble the packs and look at the wear grooves on the clutch surface. There are diagonal lines on the face of the clutch...if they are just about gone or non existant then its time to replace. You also want to look for hot spots on the steels and lay them on a flat surface to check for warpage.
Bands..you want to look for blackening and thinning of the material.
Old 09-06-2010 | 06:49 PM
nvr-enuf's Avatar
So no way to know when your tranny is about to go / leave you stranded?
Old 09-07-2010 | 07:50 AM
2007 5.9's Avatar
Fluid color and smell is a good indication of trans condition....if its dark and smells burnt..then its becomming time.
If its nice and pink and smells like good trans fluid...then all indications are that the internals are working properly.
This is all provided that you havent changed the fluid in the last 5000 mi.
JMZ
01-21-2005 11:57 PM
vtailflyer
02-29-2004 07:55 PM
Tackett
04-07-2003 02:08 PM
OH Sick
12-13-2002 04:45 PM
ROCKNRAM
11-20-2002 05:20 PM
Quick Reply: Trans Clutch Disks - How do I know how much is left?
