tranny shifts from 1st to 3rd ???
Hi all youve heard me wineing about my 06 2500 truck well finilly saved up enough money to take it to rods transmission shop in houston tx well they said they put all new parts in side and new t/c but they dont know why it shifts from 1st to 3rd so there waiting for some one to come by and diagnose it for them ??? they were supposed to deliver truck last tuesday help???????!!!!!!!
Thanks ill try that but my dodge is at dealer rt now rods tranmission rebuild my transmission they put new t/c new valve body new high energy shift parts inside now she shifts 1234 and will haul as# but if you come to a stop in gear she still pulls and if you pull up to a 6" curve she wont clime over she wont rev up she just sit there ???? rods transmission was so fustrated that they take it to a independant mech and got these codes p0251 p0088 p0606 and blamed it on engine saying its not tranny its engine if engine wood rev up it would go over curve ???? so i paid them and took it back to dealer now dealer calls and says its the tranny i told them it was just rebuilt by rods and they said take it back to rods????? they did not have an explination they said it needs a new t/c new vb and rebuild kit or they recommend a new tranny !!!??? win i told them it just got new t/c vb rebuild kit they studdered my truck now has 99405 miles what to do i cant afford to just park it??? any sugestiond ??? pete
What kind of VB did they put in? I know when I installed the DTT VB in my old 03 I also had to install a voltage regulator spliced into the PCM wiring so it would shift properly. It's possible that your trans is starting out in 2nd gear instead of first too. That is real bad for the trans....
OK. So they put stock parts back in. Did your trans shift like this with the old Valve Body in it? If not then I would lean towards an improperly adjusted or defective valve body....
I believe that the truck overall shifts better and will haul as@ but the problen is if i pull this truck up to a curve and stop then push all the way down on accel it wont rev up to go over . the outher new problem sence rebuild it studders on take off 1-2nd the last and most anoying is when you come to a stop it fells like your holding the brake and accel at the same time when infact im only holding break win you let off the break it leaps then amost stops??? went to dealer after they said its the transmission and i told them it was just rebuilt and they now say that they will reevaluate it win there mech gets back from dodge school so i left it there for that . they said it need a new vb new t/c and new rebuild hah but after telling them it already had them put in now they will check the engine
for the codes i orig gave them ???!!! remember my truck has 99400 miles and i believe they wanto avoid warranty work until they get a big fat check on the tranny then theyll fix the engine prob??!!! [bounds dodge] help.
The symptoms you just described sound like a torque converter issue. Sounds to me like there is more than one issue here too. PM me and I will direct you to a guy at another site that is a transmission wizard.....
update dodge says its the t/c well can any body tell me why when i pull up to a 6" curve and stop then put in drive and push accel to floor why wont engine rev up it just idles to [dodgezilla how do i pm you oh and thanks for advice ]pete
what do you mean beefing the tranny and its suposed to be a new t/c new rebuild kit new vb all installed atsame time and its doing the same bad symtoms as before rebuild.pete
I was wondering if tightening the tranny would bring out the worst in a worn torque converter. Still hard to figure how that would keep the engine from revving.
jshaw214
03-31-2008 08:56 PM
jshaw214
01-05-2008 09:15 PM
bigbaddiesel
11-23-2002 02:33 PM
