Tranny problem?
Old 04-22-2007 | 08:31 PM
oilfield-trash's Avatar
Tranny problem?
At highway speeds when I let off the accellerator I get sound like I got monster mudgrips on my truck. It sounds worse when I push the clutch in. the truck also shudders right when it comes to a stop. Any ideas? Truck has 67,000 milese on her.
Old 04-23-2007 | 06:46 AM
back to top
Old 04-23-2007 | 08:07 AM
Hvytrkmech's Avatar
At first glance it sounded like a bad shaft bearing, BUT after rereading your post, I would pull the entire driveshaft out and check your u-joints and carrier bearing, the low speed shutter usually tends to be u-joint related, while the high speed noise you hear could be a bearing or a u-joint.
Best of luck
Old 04-23-2007 | 11:11 AM
elirandolph's Avatar
I would say u joints
Old 04-23-2007 | 01:07 PM
Dropped it off at a well respected tranny shop here in corpus. Ace Transmissions - these guys are fair priced and honest as the day is long.
He said "sounds like a u-joint"
Ill let you guys know.
thnks
OT
Old 04-23-2007 | 03:21 PM
XLR8R's Avatar
What tires are you running?
Old 04-23-2007 | 05:14 PM
highway tread firestones
Old 04-23-2007 | 06:35 PM
06megacabman's Avatar
Next door neighbor had a similar issue and the dealership ended up saying he had a froze up u-joint. Replaced the u-joint and that section of driveline.
Old 04-25-2007 | 03:11 PM
I posted this on TDR and DTR.
And the winner is DTR. It was a rear u-joint.- Trucks runing great.
Black Dog
12-03-2009 08:18 PM
high bid
08-02-2007 06:08 PM
ezdemon72
14
07-29-2005 10:05 AM
mikie1234
12-25-2004 12:54 AM
silverram323
24
11-09-2003 07:48 PM
Quick Reply: Tranny problem?
