Tranny Light On!
Old 02-24-2007 | 07:56 PM
mtblackdog's Avatar
Tranny Light On!
I just had my tranny light come on today, I wont be able to call the dealer until monday, just looking for some thoughts as to what is going on. Light is solid, 43,000 miles on 05 truck, been using the four wheel drive on snowy roads alot lately, transfer case seems a bit nosier than normal, but nothing alarming, no shifting problems, tranny fluid is fine. So any thoughts?
Old 02-24-2007 | 09:40 PM
Tony T.'s Avatar
Have you checked to see if any codes are showing, you know cycle the key a couple or three times to read them where the odometer is located, if any. Then maybe someone can tell you what the code relates too. Justa thought!
Tony
Old 02-25-2007 | 12:53 PM
mtblackdog's Avatar
re
Code is P0514, thanks for the help.
Old 02-25-2007 | 06:40 PM
Tony T.'s Avatar
You may have already done some searching but the code PO514 relates to battery temp sensor voltage too low. Did you try cycling the key any more after you found the PO514 code to see if any other codes came up.
Tony
Old 02-25-2007 | 07:00 PM
J BODY's Avatar
514 is erronious .....there is a flash to correct that.
.....and I guess I'm lost. What "trans light" are you seeing?
Old 02-25-2007 | 08:55 PM
bluebull's Avatar
I assuming he means the temp too high light for the auto tranny.
stratos201proxl
01-16-2014 11:04 AM
Joey-D
12-12-2011 12:52 PM
Black Dog
12-03-2009 08:18 PM
FD5
04-03-2008 05:55 AM
boughtadodge
12-04-2002 11:18 AM
Quick Reply: Tranny Light On!
