Tranny leak at inspection plate.....
Old 05-14-2008 | 01:29 PM
ptgarcia's Avatar
My 48re is slowly dripping tranny fluid from the inspection plate. I pulled the plate and there is a tiny bit of fluid in there. This isn't normal, right? What could be the cause? Leaking seal or something?
Old 05-14-2008 | 09:00 PM
HIGHGEAR's Avatar
Mines doing the same thing as well, I'm thinking the torque converter seal is leaking. Just got done doing my front crank seal, next is my rear main seal and converter seal. I got 110000 on the truck.
Old 05-14-2008 | 11:49 PM
mudder500's Avatar
I got 24k on mine and it leaks from the inspection plate and the trans joint where it bolts together.
Old 05-15-2008 | 09:32 PM
dozer12216's Avatar
An occasional drip is not a leak. Lots of these units show some wetness in indiacted area. Could be oil getting past vent, seep to lube the sipes on hub seal, and more.
btoops
08-13-2011 02:24 PM
Nate-03 D
07-19-2011 06:08 PM
ArXane
14
04-18-2009 08:50 PM
DL1221
07-23-2006 01:45 PM
Quick Reply: Tranny leak at inspection plate.....
