tranny fluid change ?
#46
Take out two screws and the filter falls in your hand.
I love it when parts guys tell you their part must be right because the book says so!!!
And I don't buy cheap filters anymore. Had a Fram disintegrate and plug the oil passages in a 460 Ford once....
ONCE......
ONCE......
#48
That was a great job adding the drain plug Msiminoff !
Since I don't have such equipment, I had planned on getting a new PML transmission pan Geno's maybe for Christmas.
It has a drain plug. Will I need a new pan Gasket? I guess I might as well get the kit from Geno's as well.
When I drop the transmission pan, and the filter is there; Is it pretty easy to change? I don't want to mess up anything in the transmission.
Get a big pan and put down some cardboard or newspaper!
If you want a deep pan, spend the money, if not go to Napa and get a drain plug, all it takes is a drill. Drill the hole, put some silicone between the plastic washers and done!
25
#50
#51
Not sure but you I have a set for my cordless drill that has some small hex and torxs in there and I used it.
#52
Torx 25
Thanks PSD1. Torx 25, writing this down. I appreciate it.
I will service the transmission myself when the time comes.
Filter probably goes in one way, so I shouldn't mess that up. NAPA filter. Got it.
#54
Just did my 2nd change. Every thing looked good. Had a little metal on the magnet, but the fluid was still nice and clean. Now I got to go buy another quart of atf for my T-Case. Tranny tooks 6.5 quarts
markm4
07-29-2007 11:16 AM
