tranny fluid change ?
Did mine on Monday, added a drain plug, new filter and 7 quarts of the +4. I did let it drip for quite a while. The previous owner had dropped a magnet into the pan, it had some "fuzz" on it, but no real metal. My plans for the future are to drain and drop the pan and change fluid/filter every 20K.
Whoever said that the smell test doesnt work with the +4 wasnt kidding...this stuf stinks to high heaven brand new!!!
+1, and to add it's more involved and complicated. Remove the return, get back up start the truck, drain, get back up turn the truck off, then you gotta remove the pan anyway to clean it and replace the filter, then refill, then restart the truck and then keep constantly checking and recheck until you get enough fluid....etc. Dropping the pan, changing the filter, and refilling the fluid with the amount that came out is just a much simpler task.
I just drop the pan, and for some reason I always put in just over 7 quarts.
Can I damage the pump or anything by pulling the drain line and running the truck? Do you just shut it down when you see fluid sputtering? Do you drain the pan first?
I have to put a drain valve in too.... I'm tired of the mess when dropping the pan.
Like I said earlier, if your fluid is in good shape that's fine. You make it sound much more of a pain that it actually is. I didn't have a drain plug the first time I did mine, by pulling the line I didn't have to worry about spilling fluid everywhere. Much easier to drop the pan.
For what it's worth, I didn't have a drain plug when I dropped the pan 2 weeks ago, nor did I install one before I put the pan back on, and I didn't spill any. The key is to take your time and be patient, let the fluid that is above the pan drain out, and then lower the pan at an angle while using the bolts to keep one end of the pan secured to the trans. Once the flow is down to a few drips just press the pan back up to the trans with your hand and remove the remaining bolt or two with your other hand. Then lower the pan down slowly and dump it in an oil catch pan. And there you have it, IMO a much simpler method.
I'm not trying to personally start a war here, but with the "pumping the fluid out" method comes more steps, and more steps make it more of a pain...
Oh, and the removing bolts and lowering one side of the pan is more difficult and time consuming than dropping the pan with about a qt in it. Not sure what you use for a drain pan, but I like to use an old plastic trashcan lid over a 5 gal bucket. A couple small pieces of duct tape keep will keep it from sliding around on the bucket.
I am not trying to start a war either - I told you dropping the pan is fine if your fluid is in good shape. I have done it many times myself. My fluid was bad, very dark. I just wanted to change more than 6qts without taking it to a shop.
Oh, I would ALWAYS drop the pan and change the filter. I have replaced too many transmissions in my years. I am installing a drain plug just so I don't have to drop the pan on a full tranny.
The thing I hate is having to keep a couple bolt sin and see the pan bend and flex on those bolts. I'll just drain it and then remove the cover.
Another option is to get a Mag-Hytec double deep trans pan. It has a magnetized drain plug and holds 4 additional quarts of fluid. It also gives an easy place to mount a trans temp gauge probe and has fins to help with cooling.
Just order a B&M kit, or just about any auto parts store should have one. Drop the pan, drill a hole and install the plug.
pdogg, I like your idea especially since I am installing a drainplug. Good idea and this way I don't have to touch the VB on my trans that shifts perfectly.
CamperAndy, I drove around town for over an hour with the temps constantly rising to 225 degrees and dropping again when I got moving. I was really not concerned that much about it until I finally got back home and smelled the fluid. It definitely did not look or smell as good as it had before I started towing the heavy trailer around. I'm not sure if the trans fluid has ever been changed so I'm just gonna do this and then I'll do it again in a week or two...
Most of the drain plug kits are two piece the first part goes through the hole that you drill and sandwiches gaskets on both sides of the pan the second is the drain plud that screws into the first part
