Tran Valve Body Park Issue
Old 06-24-2014 | 09:40 PM
Dynocon's Avatar
I have read several post on the stuck in park issue and that several have replaced the valve body or upper valve body. Does the upper valve body come with new rooster comb? What is the best after market valve body?
Old 06-25-2014 | 10:58 AM
PWong's Avatar
Check out the "TransGo #TF-Detent" valve body detent ball repair kit. Just drop the valve body and replace the detent ball with the detent bullet and spring.
Old 06-25-2014 | 09:47 PM
Dynocon's Avatar
I will, thanks
Old 06-27-2014 | 09:29 PM
Dynocon's Avatar
The mechanic pulled the valve body off and the detent ball and the comb we a little jammed and slipping on the shaft, he removed the burs from the comb, ball looks fine, now turns by hand easy where before it did not, stuck it back in and now determined that the rod that this pushes back in the trans is hung up. Any words of wisdom?
Old 06-29-2014 | 06:19 PM
Dynocon's Avatar
Spoke to local Dodge dealer yesterday and they thought it could be a pressure transducer or transmission governor solenoid, any thoughts?
Old 06-29-2014 | 06:20 PM
Dynocon's Avatar
Spoke to local dealer yesterday and they thought it could be a pressure transducer or trans governor solenoid, any thoughts?
Old 07-03-2014 | 08:49 PM
Dynocon's Avatar
Took to a transmission shop, guy pulled the pan took a look, filled and started up, shifts fine. Rooster comb was the issue, smoothing it out with a dremel fixed it.
fordkiller43
02-02-2008 01:07 AM
Megaramasaur
12-09-2007 04:32 PM
rkelso98
03-03-2005 05:35 PM
ramguy
06-30-2003 03:01 PM
