towing in 5th gear
Old 06-27-2009 | 06:07 PM
dieselengineer's Avatar
towing in 5th gear
I have NV5600 and to keep the temp in check in the 5600 I tow in 5th gear. This told that it is the strongest gear. Is there any problem driving all day in 5th?
Old 06-27-2009 | 06:23 PM
BLACKBEAR's Avatar
I would only stay in 5gear if the was in hill country if you have some flat land and down hill I would use 6gear. If you will put on two gauges on your truck you could tell when to shift it.A Pyro and boost will tell you a Lot And save you money in the Long run==Good luck
Old 06-27-2009 | 06:32 PM
Thanks for the info, do have EGT and boost gauges. I have 19.5 wheels and 3.73 rears so 5 gear is like 6 gear and 4.10s. Pulls real nice with comb in 5th. 23000# GCVW
Old 06-27-2009 | 07:09 PM
Diesel87's Avatar
Just depends. If the the truck lugs while in 6th yes go down to 5th. But as long as your not in the hills 6th should be fine. Just keep your boost up and your egt's will be fine.
Old 06-27-2009 | 07:26 PM
I was more concern about the tranny. Does running all day in 5th hurt anything?
Old 06-27-2009 | 08:06 PM
RiverRat2's Avatar
I dont see how it can hurt with the 19.5" 's you should be good to go,,,,
I sent you a PM,,, BTW
Old 06-27-2009 | 08:17 PM
MikeyB's Avatar
It's not going to hurt it running in 5th. Depending on the speed and rpms you might be able to gain some fuel economy by using 6th on flat terrain.
Also a good idea to add an extra quart of fluid in the tranny to keep the upper bearings well lubed.
MikeyB
Old 06-27-2009 | 09:38 PM
Thanks MikeB. With the 19.5 I am running 2200 to 2300 rpm in 5th. Have the fast cooler and the extra oil 7qt total. The tranny temp max 190 when in 5th. Without towing 6th is great for crusing
Old 06-27-2009 | 09:57 PM
RiverRat2's Avatar
Check your Private Messages
Old 06-27-2009 | 10:28 PM
C Schomer's Avatar
5th is direct (straight thru) so no power goes thru the countershaft. You won't hurt anything running in 5th, indefinately. The countershaft is still spinning and throwing the lube around. 190* is very good! Mine runs about 215 on a hot day, towing in 5th or 6th. Craig
Old 06-28-2009 | 07:18 AM
RiverRat2's Avatar
Did you add a tranny temp guage???? what brand????
Old 06-28-2009 | 12:35 PM
A sensor on each side, isopro analog and commander on the other. The drivers side runs about 5 to 8*F cooler. Have a fan / heat sink on the driver side, the exhaust is on the other side and there is no room with a 5 inch down pipe.
Old 06-28-2009 | 05:56 PM
C Schomer's Avatar
I drilled and tapped my diff and pto covers and put in immersed wells made from old rtd probes. Then I made my own TCs from bulk rolls of TC wire and ran them into the cab and put mini-connectors on the ends so I can plug them into my Fluke 52. Craig
Old 06-28-2009 | 07:49 PM
What does your rear diff temp run while towing?
LemonDodge
09-07-2019 03:51 PM
LemonDodge
09-16-2010 07:33 AM
SeanB23
04-16-2010 06:20 AM
Ramdriver15
06-25-2008 08:48 PM
wadecool
11-13-2006 12:37 AM
Quick Reply: towing in 5th gear
