torqu specs
high pressure injector supply lines to 22ft lbs
exhaust valve rockers tighten to 27ft lbs
Torque injector hold down nuts to 89in lbs.
I pulled these down from:
http://www.dynomitediesel.com/user_p...20Instructions
sounds like you just replaced the injectors, so hope that page helps some.
oh, and be carefull with the injector hold down bolts, they can shear off pretty easy if you go over torque spec.
did the injectors and then some investigating. I have a strane tapping noise now. I did talk to my diesel guru. i took notice of some smal metal nubs on the rocker bridges he said to point them toward the exhaust. (not sure if this will cause tap) But i will be opening er back up tpnight to arrange correctly. any input
http://www.dodgeforum.com/m_910497/tm.htm
someone hooked me up with this awesome write up, so give it a shot, its really easy. good luck.
BlackBeast
12-31-2006 12:26 PM
06RAMCTD
0
12-19-2006 04:15 PM
