tire pressure
Old 12-20-2005 | 07:26 PM
marc03's Avatar
tire pressure
Is anybody running 325/65/18 tires? At what psi?
I'm running 45psi all around a it looks like my rears are wearing just in the centers.
Old 12-20-2005 | 08:53 PM
Nate-03 D's Avatar
I'm running 35's on 17" wheels and I currently have mine at 42 psi all the way around. No wearning at all. But then again they have less then 3k miles on them.
Do you rotate them often?
Old 12-21-2005 | 10:10 AM
marc03's Avatar
I only have about 1500 mi on them but the little "nipples" that come on new tires are worn of evenly on the front, but only the center ones have worn off in the rear. Thant is what makes me think the centers are wearing.
Old 12-21-2005 | 12:49 PM
jkitterman's Avatar
Did you put the tire on too narrow of a rim?
Old 12-21-2005 | 01:45 PM
marc03's Avatar
dont think so the rims are 9.5" wide
Old 12-21-2005 | 02:07 PM
cquestad's Avatar
Drop the rear to 40 psi while unloaded and they will wear flat...
Old 12-21-2005 | 06:59 PM
rickkari0304's Avatar
I noticed the same thing on my STT 35's. The front driver's side inside little thingys aren't worn off yet. I think these stock rims are too narrow for the tire. I can't afford new wheels so I have to deal with it. I wonder how low I can go on PSI safely?
Old 12-21-2005 | 07:51 PM
cheff's Avatar
Yep my 315's did this if I left them fully inflated after towing. (only in the rear) Use to run 38-40 on rear and full on the front. The Procomps are fully inflated all the time and are wearing great. I only wish they were E rated.
Old 12-21-2005 | 07:55 PM
cheff's Avatar
If running empty you could go as low as 35lbs, any lower and you will be producing too much heat. Don’t forget to fill them up if you are towing.
Dave88LX
14
09-01-2011 11:36 AM
4RnrRick
02-27-2007 11:25 AM
I PASS GAS
05-12-2006 11:19 PM
FrankB
08-17-2004 12:27 PM
ffemt1271
16
01-09-2003 11:19 PM
Quick Reply: tire pressure
