Tips for 48RE trans service
Old 07-13-2007 | 10:57 PM
DreamSRT6's Avatar
what about Mobil 1?
i see everyone putting in ATF+4, but what about Mobil 1 Syn ATF? in the tranny....bad idea? just curious
Old 07-14-2007 | 04:40 PM
Deesil's Avatar
Muted User
I just did a tranny service on my truck today.
Removed the pan, adjusted the front and rear bands, changed the filter and FINALLY I put in a dang drain valve in the stock pan. I was kicking myself for not doing it last time.
Now I can flush out my tranny the easy way!!!. Run it for 15-20 minutes....drain out 4 qts....put four back in, run it for 15-20 minutes and do it again. I put on a petcock with a nipple on it so I can put a short hose on it and drain it right into an empty milk jug for disposal Takes about 10 minuts or less. The only downside is that I will only be able to do about 4 qts at a time BUT absolutely no mess. I put the drain valve on the back side near the rear band adjuster so I don't have to worry about something hitting it and breaking it off.
So from now on, I'll drain out 4 qts and replace everytime I change my oil. That might be a little much, but I'm fanatical about maintenance.
Old 07-14-2007 | 04:57 PM
DieselAvenger's Avatar
I cant speak for the 48RE, but in a 4L60E, I lost two transmissions in 10 months with synth fluid due to the clutches slipping. Switched over to a standard ATF and no problems afterwards until I broke the drum.
Old 07-14-2007 | 05:06 PM
annabelle's Avatar
ATF+ 4 is the only fluid approved for a 48E. It is synthetic.
Old 07-14-2007 | 06:21 PM
Deesil's Avatar
Muted User
Yep, putting in anything else will make you regret it in a real hurry.
ghstrider87
04-26-2012 06:35 AM
Rob's Red Ram
01-07-2012 06:40 PM
plessm
22
11-01-2010 10:46 AM
dieselbeef
06-12-2006 08:12 AM
tanderson2002us
10-14-2003 05:43 PM
Quick Reply: Tips for 48RE trans service
