ticking when key is cycled on and ticking stays constant
ok so i have this ticking when the key is on it is pretty fast and constant. i havent noticed it before and am wondering if it is just the injectors bleeding the air off? i have a lift pump failure code and havent noticed it until this code came up in the truck i have a fuel boss so i have a fuel pump just want to know if it is normal and how do i get rid of the lift pump code? thanks
Injectors #1 and #6 will cycle when the ignition is in the run position and no engine rpm's detected. They are bleeding rail pressure and any possible air out of the rail preparing to start. Perfectly normal operation.
I always figured it was something like that.. Thanks.
CarBizIndio
05-29-2007 12:33 PM
Fisherguy
06-24-2006 06:44 PM
steelydan
12-25-2005 01:59 AM
trik396
04-26-2005 09:21 PM
big red psd cc
12-29-2004 11:38 PM
