Threaded pipe plug at rear of head leaking coolant
So I had the slow coolant leak in my '06 that I noticed when I turned the motor off. I went to the local Mopar dealer and got the new piece of 3", 7/8" diameter heater hose and spring clamps, and spent 2 hours on Saturday replacing that piece of heater hose underneath my exhaust manifold that's right next to the turbo. I was hoping that would solve the problem, but . . .
As it ends up, the leak is still there. After scratching my head for a bit, I started to trace the trail of coolant on the head and the block. Where my coolant drip is coming from is on the very rear of the head, from the threaded pipe plug that's square in the middle of the head (right up against the firewall). You can see it from underneath the truck if you look up at the top of the head from between the tranny pan and the exhaust pipe. The plug is actually wet! However, the freeze plug next to it is dry-so I guess I should count my blessings
It looks like the plug takes a 1/2" drive ratchet, but I have absolutely no idea on how to maneuver one back there. I know on other threads on here that guys have seen this before and have figured out ways to get a ratchet back there to tighten up the plug.
Look at the pics and tell me what you think. One of the pics shows the $24 piece of hose .... the other one shows the threaded plug. I'm pretty mechanically inclined, but I'm at a total loss on this one...
Thanks-I've seen the matco teardrop ratchets before. I don't have one though so I'll have to look and see what buddy of mine might have one in his toolchest
Has anyone else had problems with these rear threaded plugs leaking? I can't be the only one that has
Actually I finally figured out how to tighten the plug today. I joined 2 24" 3/8 drive ratchet extensions, put a 3/8 to 1/2" adapter on the end, and then a 1/2" universal on the adapter. I fed the end-to-end extensions with the 1/2" universal on the end up between the tranny and the exhaust downpipe from the turbo, and was able to jiggle the 1/2" universal end into the hole in the pipe plug. Man that pipe plug was loose! Kinda scary-wonder how long I had before it totally worked itself loose, squirting 200 degree coolant everywhere! Anyway, I tightened it up, and no more leaks!
If you guys have a coolant leak from the rear of the block, and it's not from the heater hoses-there are two pipe plugs back there that could be leaking. The one that was leaking on mine was in the center of the rear of the head-it's tightened with a 1/2" drive ratchet. The smaller one (right behind the exhaust port of cylinder 6) takes a 3/8" drive.
BobWatts
09-14-2006 04:28 PM
trik396
12-01-2005 10:21 AM
Burpl
12-24-2003 05:08 PM
