those of you running leveling kits
Old 11-16-2006, 02:00 PM
SOhappy's Avatar
If you're worried about how it looks, just remember it levels out under WOT
Old 11-16-2006, 02:03 PM
ptgarcia's Avatar
Originally Posted by FishingFather
Thank you, I think that is what I was trying to say. You raised your front and left the rear suspension stock, then dropped a load on it and it looked level. I instead relocated the shims on the rear axle to get the same net effect (except my entire truck sits about 1.5 inches lower than yours) so when I load it, it looks level too.
Yeah, just trying to back up your info. My truck sits level unloaded, and with about 2000 lbs in back with a WD hitch still sits level.
Old 11-16-2006, 10:33 PM
triplenickel's Avatar
If you're really worried about sagging, air bags work great. Also IMO a "reverse" rake looks way worse. I think a 2.5" will put your front about an inch higher than the back. Just grab a tape and measure it to be sure, companys like top gun will custom build a set of spacers for like $79 and it will actually be level. Any truck that I've personally seen sits nose high with even a 2". I also wouldn't get too sucked in with some of the expensive levelling kit manufacturers claims to some wonderful engineering. While the springs may be fantastic and ride great, they are simply overpriced. they serve the same purpose as a $79 spacer, or a Superlift spring, they just push the axle away from the frame. There is no correction for the track bar, or trailing arms. As for sway bar drops, a piece of steel and some bolts works just as well as the super expensive shiny billet ones with a logo CNC'd in the side. Just my .02. Where do you live? the reason I ask is i have some 1.5" spacers from before I did my 4.5", not that it matters but they have less that 2000 kms, and they could probably disappear for a bottle of whiskey if your local.
Edit;
Once I maxed the caster it drove perfect as well, you will be happy with whatever you choose.
Old 11-17-2006, 02:28 AM
Gary C's Avatar
With my 01, 04.5 and 06 Cummins I leveled all the trucks out by removing springs, dearching and then adding bags. Never had a problem with any of them. The ride is so much better and can tow the 10k tag with no problems with never worrying about head lights looking for squirrels when loaded or worms when unloaded...
I personally like a touch of squat in the rear but have the option to make anyone happy...
TheNeckasaurus
10-13-2010 08:16 PM
customizedcreat
05-19-2010 01:44 PM
Iron Mike
04-10-2009 07:42 AM
LFD2037
02-16-2007 09:34 PM
Townsend600
17
12-21-2006 09:15 AM
Quick Reply: those of you running leveling kits
