Thinking about changing from 4.10's to 3.42's - mileage, performance, etc
Old 08-15-2007 | 12:27 PM
nvr-enuf's Avatar
Fuel savings
I am willing to bet a 2 mpg fuel savings, which in 44K miles to recieve your payback. Also consider the lowered amount of rev's on the motor as a benefit.
SAS
Old 08-15-2007 | 09:54 PM
NickBeek's Avatar
Originally Posted by nvr-enuf
Go to http://www.justdifferentials.com/ to find the 3:42 gears.
I found the gears for the 11.5 rear, but not for the front (9.25 I think). Does anyone know if the GM 9.25 front diff takes the same gears, cause they have them.
Old 08-16-2007 | 01:53 AM
Little03's Avatar
JMO but I would Trade another member on this fourm your 4:10's for there 3:73's and I think you will get 20mpg empty, my dad has 3;73s with a 6sp in his 03 and at 115 to 120km his tach sits at about 2150 or 2100 rpm and thats where he see's the best fuel economey.
I have 03 as well with 3:73's and i get 20mpg at 2150 at 120kmh.
Old 08-16-2007 | 12:26 PM
nvr-enuf's Avatar
MPG with 3:42 gears
I spoke with the guy at "Just Differentials" and they do offer the 3:42 for both diff's on a 2004 dodge.
The price is $975 for both sets of gears and the complete install kit (shims, crush sleeve, spacer, etc.).
The price w/ complete bearings is $1275
Fluid - They suggest 80-140 weight Richmond GL6, $10 per quart, takes about 8 quarts.
He said a lot of people have ordered this kit and stated the increase in mpg is 2+. For 2 mpg, I think I am in, especially if it lowers the noise and less turning of the motor.
Old 08-16-2007 | 01:44 PM
realsquash's Avatar
2mpg? I can feel the Visa card burning a hole in my pocket... I don't trust what most people say about their mileage, including vendors. But I do think these would help.
Andy
Old 10-30-2007 | 04:59 PM
Mr.DieselMan's Avatar
2 MPG Good Idea
I have heard from several different source that you can easily get a 2+ MPG gain by doing the conversion to the 3.42! I would go for it if I was you!
Old 10-30-2007 | 07:37 PM
nitis's Avatar
Ican only imagine thesealong with my 35s a match made in heaven with this darn g56 but I cant quite pull the trigger cause I really want the new quad x2
Old 11-02-2007 | 03:51 PM
aggie98's Avatar
35" tires with 4:10 gears has the same final drive as a truck with 3:73's and stock tires... You can have someone with a scan tool change your computer's setting to 3:73 so your speedo & such are correct.
It would be cheaper...
BTW: This is how my truck is set up and I see about 1900 RPM @ 70 with the 48re.
apocalypse1812
02-24-2010 06:11 PM
slowstang232
03-31-2008 08:23 AM
mhuppertz
06-21-2007 09:23 PM
t-boe
05-08-2007 09:01 PM
turbo dreams
11-21-2005 06:25 PM
Quick Reply: Thinking about changing from 4.10's to 3.42's - mileage, performance, etc
